Drive Train Axles Bearings problem
1997 Ford Explorer 6 cyl All Wheel Drive Automatic 150K miles
I have a loud "BANG noise when I start off and it usally will make this noise 1 to 2 times and its LOUD. After the bangs it runs good. Sometimes if you take off slow or not alot of load you will not hear this BANG. Also when the noise happens you will be moving at least 10 to 15 miles per hours. I have rebuilt the T-case a few years ago so I have ruled out the chain slapping the case. I beleive it is the diff. limited slip but I have never ran accross this noise happening when and how it does. Thank you for your thoughts on this issue.
Sep 26, 2009 at 10:31 AM
