1997 Ford Explorer Head Gasket?
1997 FORD EXPLORER
205,000 MILES • 6 CYL • 2WD • AUTOMATIC
DOUGH40
On the way to work my truck seemed to be slipping inot neutral. After finally getting to work I smelled burning and there was smoke under the hood. When I lifted the hood it was hissing and looked like chocolate milk had exploded under the hood and the same brownish fluid began puddling quicky under the right front headlight on the ground. Is this most likely my head gasket? If so, is this a pricey repair?
Mar 29, 2008 at 8:41 AM
MIKE H R
  • 3,094 POSTS
I would start with your cooling system with 205000 miles on the truck it probably needs to be flushed. and the thermastat replaced. you can take it and do a pressure check to see if there are any leaks. the brown fluid under the headlight is from the overflow tank. After you put more coolant back in how does the truck act? It could have a blown head gasket but I would start with the cooling system itaself especially the thermastat and flushing it out.
Mar 29, 2008 at 9:58 AM
2CARPRO JACK
  • 11,533 POSTS
Might have broken the radiator at the trans cooler.Look where the lines go into the radiator
Mar 30, 2008 at 7:55 AM
