1997 Ford Explorer failed emissions test in chattanooga tn
1997 FORD EXPLORER
15,700 MILES • 6 CYL • 2WD • AUTOMATIC
SPORTSMOM367
Just found out what the code meant that was on my failed emissions test Just curious on how hard it will be to replace the Idel air control valve can I do it myself or should I take it to a professional mechanic Advanced looked up the code P1507 and said it was an idil air control valve is that correct thanks
Dec 30, 2008 at 10:47 AM
JGAROFALO
  • 489 POSTS
This should be an easy DIY repair. This device is locared on the throttle body, on the top of the engine. Replacing it is a matter of unplugging the electrical connector, unbolting it, and reversing the procedure to install the new one.
Dec 31, 2008 at 6:09 AM
