1997 Ford Explorer Dashboard lights
1997 FORD EXPLORER
DPRAT.TX
Electrical problem
1997 Ford Explorer 6 cyl Automatic 120000 miles
When the dashboard light is on, the RPM and the battery monitor display are barely lit up. The rest of the dashboard has light. I checked the fuses and do not see any fuse that appears to be broken. Which fuses do I need to change out for new ones or is there something else I need to check?
Feb 2, 2009 at 8:18 PM
WORKMAN57
You might try replaceing the bulbs. I recently got a 97 explorer in which all of the dash lights were burnt out. It is a real pain to replace them, but it can be done.
Feb 28, 2009 at 5:11 AM
