Engine squeak
1997 FORD EXPLORER
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
BRIANNAHHHH
I heard a belt noise coming from under the hood, I took it to FORD, they said that I needed a new Serpentine belt, and a pulley tensioner because it was broken and cocking my belt to the side. I changed both, and the noise continued. I changed the altenator because the pulley on that was making a clicking noise, but the noise is still happening?
Nov 11, 2010 at 4:45 AM
WRENCHTECH
  • 20,761 POSTS
I think your problem may not be coming from the belt at all. This noise is commonly misdiagnosed as a belt noise when in reality the noise is coming from the Cam Sensor synchronizer. That is the drive mechanism that the Cam sensor is mounted on and it's located where the distributor normally would be. You can use a long screwdriver to your ear and the base of the drive to listen for the noise. DO NOT remove or move that sensor without marking everything very carefully. This has to timed and requires a special tool to do this.
https://www.2carpros.com/forum/automotive_pictures/561653_Cam_sensor_synchronizer_97_40_1.gif
Nov 11, 2010 at 7:08 AM
BRIANNAHHHH
Would it get louder as I accelerate?
Nov 11, 2010 at 10:14 AM
WRENCHTECH
  • 20,761 POSTS
Possibly, check it and find out.
Nov 11, 2010 at 11:10 AM
JRAYLONG
My engine is making a ticking noise. I can feel a vibration through the dipstick but I don't feel the vibration on the headers. I have a 97 Ford explorer 4.0 sohc
May 30, 2020 at 11:35 AM (Merged)
CARADIODOC
  • 34,306 POSTS
A common problem is worn push rods where they contact the rocker arms. you will hear it more if you remove the oil fill cap and listen there.
caradiodoc
CJ MEDEVAC
  • 11,004 POSTS
As your engine gets older, you will get rattles in your valve train...From wear and maybe from your tappets (hydraulic lifters)...The tappets sometimes get "dirty" or build-up on the surfaces of it....then they do not perform as intended!
The tappets sorta work like a Hydraulic Jack but much faster!
When they drop down, due to the cams action, they sink into a OIL GALLEY, oil pressure "OPENS THEM" and RE-ADJUSTS THEM to take up the SLACK from WEAR in the push-rods, rocker arms, valve stems, cam, and even the mating surfaces of the tappet itself and this "ZEROS" each one to the Proper height......EVERY TIME IT GOES DOWN!
The Cool thing is, It "CLOSES" as it comes back up, closes like a hydraulic Jack....Then it starts pushing, the system, and Wah-lah...the valve opens
May can help you Squeeze out some more miles and help to quiet the ticking!
When you perform your OIL CHANGE, SUBSTITUTE, a QUART of-----Marvel Mystery OIL-----for a quart of regular oil........This will CLEAN your Lifters (tappets)........This may get rid of rocker-arm rattle completely..........or maybe not....but it will harm nothing!
The goal is to get the Tappets clean and Closing correctly as well as the "Opening"--Re-adjusting part too........"MMO" does not need to be used every oil change
Next, My next oil change and "ALL" thereafter, I would use "LUCAS OIL STABILIZER" or "High Tack" (does not have to be the $$$ synthetic type).....This is some thick stuff, may take 30 minutes to get it to all run out of the bottle....I set mine over the heat vent inside,for a while till I install it.
Stabilizer adds $$$ to your change, but it will prolong engine life...at least thats what I have experienced.
I use it in ALL OF MINE.......Nothing is too good for "Mr. Jeep" ('77 CJ5) and "Willy" ('46 Willys)
Respond with GOOD NEWS....Don't forget me!.......Whenever!....I can wait thru your 2 oil changes!---RESPOND at this post....so I will be alerted
The Medic
JRAYLONG
Thank you for the quick replys. I have since stopped the rattling in the oil pan. It seems that when I changed my spark plugs(One was blown out of the engine and I have to tap a new hole and put a insert in) it seems that the dipstick was moved to where it stuck too far into the oil pan. I moved it back out a little and the knocking noise stopped. :)
CARADIODOC
  • 34,306 POSTS
Interesting. So how do you know when it's in the correct depth to read the correct level?
I should have clarified too about the noisy push rods. That is a different problem than the typical valve lash noise caused by lifters that aren't pumped up. There will be grooves worn into the ends of the push rods that cause a clicking or chirping sound.
caradiodoc
BBEARD91
My check engine light just recently came on and I noticed a funny noise coming from the engine bay. It sounds like someone is running their wet fingers on a crystal wine glass and it only happends between 1k and 2k RPMS.Thanks in advance
BILLYMAC
  • 2,204 POSTS
hi can you tell if this noise is in the front of the eng or sides or back?
does it sound like a rubbing noise rattle noise ?
if you will answer these questions i will try and help
thanks billymac
CJ MEDEVAC
  • 11,004 POSTS
Well Caradiodoc, That seems awful weird about the dipstick.
jraylong, be careful tapping that out, I just recently learned, that when TAPPING ALUMINUM, use "LARD" for a lubricant....If you know someone with experience with "Helicoils" or Inserts, Their help may make it a GOOD Thing....'Stead of a BAD Thing.
Sorry I wasn't much help
The Medic
BBEARD91
I took it up to advance auto parts and they said it sounded like a bearing in the alternator or idler pulley going out. The noise is on the front side of the motor towards the top.
JRAYLONG
Someone suggested to use grease on the tap. It worked very well. Not only did it make it easier to cut but it also created a sticky trap for all the metal shavings. As for the depth of the dipstick I had measured it before and after moving it and it only changed a fraction of an inch. I didn't move it very much at all. Just enough to get it out of the way of whatever it was hitting. :) I thank you for your speedy replies and the knowledge you have shared. I am no mechanic, but I learn by working on my car.
BILLYMAC
  • 2,204 POSTS
hi ok then remove the serp belt start truck you should hear no noisw/.turn each pulley bye hand. they should turn smooth and tight. the bearing bad will feel rough and loose and noisy. normally it will be the idler billymac
CARRIEO
My truck just started to make this high pitch noise under the hood and noticed when i press on the gas more then when i let up also its cut off on me a couple of times when i come to a stop and when i put it in park the engine seems to reev some. what could it be.
May 30, 2020 at 11:36 AM (Merged)
MERLIN2021
  • 17,250 POSTS
More than likley it's the idle air control valve, bolted to the side of the throttle body.
https://www.2carpros.com/forum/automotive_pictures/62217_IAC_7.jpg
