i have replaced the ds caliper. The scanner indicated a front ps sinser problem. Replaced sinser (broken wire). Bled the system, according to manual removing lots of old brake fluid. Still have original problem of growling during end of brake depression. Have driven car two hundred miles since completion of work and the system has not reset, in fact the growl has increased. The scanner shows "no codes".
Where or what should I persue next?
Mar 12, 2010 at 7:25 PM
