1997 Ford Explorer
1997 FORD EXPLORER
108,000 MILES • 6 CYL • 4WD • AUTOMATIC
ELIZABETH16407
When I am going down the road there is a noise coming from the front drivers side. It sounds like it's grinding when it goes a full rotation. Like when it goes around and gets to a certain spot it grinds. The steering wheel has a slight vibration. When you turn to the left the grinding still happens and gets a little louder and when you turn to the right it just about stops. When you go around turns the steering gets stiff too.
Mar 29, 2008 at 3:58 PM
DIMPLES1623
  • 4 POSTS
[quote:a2fcb85dcc="Elizabeth16407"]Noises problem
1997 Ford Explorer 6 cyl Four Wheel Drive Automatic 108000 miles
When I am going down the road there is a noise coming from the front drivers side. It sounds like it's grinding when it goes a full rotation. Like when it goes around and gets to a certain spot it grinds. The steering wheel has a slight vibration. When you turn to the left the grinding still happens and gets a little louder and when you turn to the right it just about stops. When you go around turns the steering gets stiff too.[/quote:a2fcb85dcc]
Have your CV joints and brakes checked.
Mar 29, 2008 at 6:22 PM
