1996 Ford Explorer squeals on startup
1996 FORD EXPLORER
134,000 MILES • 6 CYL • 4WD • AUTOMATIC
RAKEN47
When starting the car it produces a squealing noise similar to the fan belt squeal but has an auto tensioner and the belt is tight. I noticed small metal pieces in the air conditioner clutch where the fan belt is, could this be producing the noise?
Sep 10, 2009 at 10:51 AM
JGAROFALO
  • 489 POSTS
[quote:6ec67230d1="raken47"]Noises problem
1996 Ford Explorer 6 cyl Four Wheel Drive Automatic 134000 miles
When starting the car it produces a squealing noise similar to the fan belt squeal but has an auto tensioner and the belt is tight. I noticed small metal pieces in the air conditioner clutch where the fan belt is, could this be producing the noise?[/quote:6ec67230d1]
Without seeing the metal pieces, it is difficult to say if that is a source of noise, but a failing bearing in the clutch assembly can cause noise. Also, a weak tensioner or worn belt can cause noise.
Sep 12, 2009 at 5:41 AM
LYNDON9
  • 4 POSTS
Its your tensioner...i had the same problem and just replaced the tensioner.
Oct 28, 2009 at 7:32 PM
