1996 Ford Explorer Power Window Driver's side
1996 FORD EXPLORER
126,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAVE TRUEBLOOD
Window went down (auto-open) but will not close. All other windows work fine. Did note that the auto window lock does not work. All fuses seem to be good. How can I check to see if the motor is getting a signal from the switch without removing it? Do I have to remove the door panel to remove the motor? If so, how do I remove the panel?
May 1, 2008 at 6:55 AM
RLBSTUCKINHOU
  • 11 POSTS
YOU CAN POP THE SW OUT OF THE DOOR PANEL WITHOUT REMOVING THE PANEL THEN YOU CAN USE A METER TO CK FOR VOLTAGE WITH THE SW IN THE UP POS. IF YOU HAVE POWER TO THE SW YOU WILL HAVE TO REMOVE THE DOOR LINER TO CK THE MOTOR. IF THE SW WORKED GOING DOWN IT MAY JUST BE BAD ON THE UP CONTACT. GOOD LUCK HOPE THIS HELPED.
May 1, 2008 at 7:58 AM
