1995 Ford Explorer air condition not blowing
1995 FORD EXPLORER
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
BIGKIDISON
My air condition unit is not blowing. it works, because if i turn it on, while driving i can feels some air coming thru, probably from the outside, but there is no air blowing from the unit. can it be a fuse, a relay, is the unit bad, please help???
Feb 20, 2008 at 9:05 PM
BHUGG
  • 157 POSTS
There 2 fuses and a relay that might be bad as an easy fix. The first fuse will be in the fuse box in the dash. The second fuse is under the hood in a relay/fuse box. Check the fuse. If good, try switching the blower relay with another similar relay and try it again. The relay will be in the same box as the second relay.
If that doesn't work, you could have a bad blower resister assembly, loose wire harness connection or even a defective motor.
Feb 23, 2008 at 1:21 AM
