1995 Ford Explorer air compressor
1995 FORD EXPLORER
137,000 MILES • 6 CYL • 4WD • MANUAL
CONTROLLER1954
It appears that my air compressor has malfunctioned and was wondering how long might I be able to drive the truck with no long term electrical problems/effects as long as I dont use the A/C or heater and vent fans. the repair bill is estimated at close to $800.00, to replace the compressor and other parts, orfice tube, acclimator?? It seems that the compressor clutch locks up. could the cluth be replaced only. I know that when I use a couple of the air vents the compressor sometimes works and then it makes noises. any information would be reatly appreciated.
Feb 25, 2010 at 10:28 AM
IF you're not using it, you should be fine. You can use the fan and the heater, but the AC and defroster will actuate the compressor. You can unplug the compressor if you need to use the defroster. On the compressor, you will find a power supply to it. Just disconnect it.
Feb 26, 2010 at 2:27 PM
First, thanks for the positive feedback. Second, let me know if you have other questions.
Were you able to disconnect it?
Mar 11, 2010 at 10:00 AM
