Noises problem
1994 Ford Explorer 6 cyl Four Wheel Drive Automatic
The car has 125,000 miles and drives very well and smoothly. at higher speeds, over 60 mph, there is a vibration when you back off on the accelerator and let the engine over run. This vibration stops after a few seconds as the car slows a little or stops imediately if you start to accelerate again. I can find no obvious excessive play in any of the drive train joints or gearcase output bearings
Mar 30, 2010 at 12:13 PM
