1994 Ford Explorer Rattling noise from engine (not alvays)
1994 FORD EXPLORER
NIKOLAD
Noises problem
1994 Ford Explorer 6 cyl Four Wheel Drive Manual
In a cold days, when I start cold engine I can hear (best from drivers seat) rattling noise which is started about 1700-2000 rev.When engine is little warmed noise disappeared.Same noise, little beat quieter, ( with warm or hot engine) I can hear about 3000-3200 rev and up , but not when I drive with power (e.g uphill), only when I drive without power (e.g down hill or flat road). I think that noise came from passenger side of the engine, but it can be hear only with stethoscope (on cold engine) because from front of the vehicle it is very quite.
Now I shift very fast when engine is cold ( M5OD) and try not to reach more than 2700 rev on highway in attempt to preserve engine which have 270.000 km without any other problem, but I'm wondering for origin of that, and what I can expect in future
Apr 23, 2010 at 7:25 PM
If you are sure it is in the engine, it could be many things. Remember, unlike water, steel expands when it gets hot and shrinks when cold. Thus, if you have a worn bearing, lifter, rocker, wrist pin... when it is cold you may hear it, but when it gets hot and the steel expands, the sound may go away. With this many miles on it, the only way to be sure is to take the engine apart and check clearances, wrist pins...
Make sure it is in the engine and not something like a heat shield, water pump...
Apr 23, 2010 at 9:00 PM
NIKOLAD
I'm sure that is engine noise. But I'm not very happy to open ,otherwise perfectly working engine with full power and torque, for checking and measurement. I'm driving with that occasionally noise more than 30.000 km, and situation is not any worse. (perhaps and more km because when radio is on you can not practically hear that, it so quiet. Of course that I now hear that noise in background, once when I already know when it come and how it sound). Noise on cold engine first time appears in occasion when I don't drive vehicle for three weeks and after approx. one minute working after first start (in cold late autumn day) noise appear. When engine is wormed it disappear. From that time I already change type of motor oil from Valvoline Syn power 5w40 to Motorcraft Formula E (now F) 5w30
and maybe have little benefit but I'm not sure
Apr 24, 2010 at 4:13 AM
NIKOLAD
An again, when I need power or when engine is under load noise is not there, I'm sure.No mater of rev's.
I have already hear about some cold engine lifter problem.
And only thing what I change so far to engine is thermostat, spark plugs twice and spark wire once.
My engine is running mostly on LPG but noise is same on petrol or LPG.
Sorry ,maybe I wrote to long but I try to pinpoint problem
Apr 24, 2010 at 4:24 AM
Hi:
I agree with you not wanting to take the engine apart, and I understand why. It is hard for me to tell 100% without actually being there to hear it. However, as I explained, a cold engine is more likely to make noise than a warm one. Thus, I feel that it is a bearing. Have you ever tried any additives with the oil when you have it changed?
Apr 24, 2010 at 9:35 PM
NIKOLAD
I never put any additives in engine oil, only MoS2 paste from Liqui Molly in gearbox.
When I try to pinpoint the location of noise I inspect all engine with stethoscope , and find some different noise from first cylinder(front driver side), something like very very slightly knocking, but cylinder balance test don't show difference btw cylinders, so I concluded that is normal wear to bearing or cylinder according to mileage, for front cylinder, which is alway in stream of cold air from fan. In my experience, always cylinder which is next to the fan (eg. straight six engine) wear much more than others.But that is not the noise which I'm looking for
In my case noise came from passenger side of engine, and thing what is most wondering is why disappear when engine is under load?Like something is going loose and knocking when you stop to load engine around 3000 rev. Is it possible to be something with timing chain or tensioner for it?
Apr 25, 2010 at 9:14 AM
It could be a worn timing chain, but they usually don't make a knocking sound.
Apr 26, 2010 at 8:14 AM
