1994 Ford Explorer power window motor
1994 FORD EXPLORER
194,000 MILES • 6 CYL • 4WD • AUTOMATIC
FORD OWNER 1994
How do I replace the window motor (pass. front) in my 1994 ford explorer?
Sep 19, 2009 at 5:55 PM
I will give you a general idea, but I do recommend having a manual to help guide you.
You need to remove the door panel to access it. The motor will be mounted with rivits. THey will need drilled out. Remove the wiring connection and remove the old motor. WHen you replace it, use nuts, bolts, and lock washers. NOTE: THere may be a spring that will come undone when you do this. Watch for it.
Sep 20, 2009 at 1:41 PM
