1994 Ford Explorer Oil pump or oil pressure sensor gone bad
1994 FORD EXPLORER
CHUDEMEN
1994 Ford Explorer 6 cyl Two Wheel Drive Automatic
I want to know, how do u know the oil pump gone bad or the oil pressure sensor gone bad? How do u test its make sure which one is the bad one?
Jul 15, 2010 at 8:16 PM
Use a mechanical gauge remove the oil pressure switch screw on and crank engine over if normal replace the switch if abnormal could be the oil pump or the engine bearings
Jul 15, 2010 at 8:21 PM
