slight miss at idle,no power throughout driving,almost stops when pulling hill then downhill runs smooth when less pedal pressure.have replaced plugs wires,coil pack air filter fuel filter,fuel pump checks ok.replaced computer,crankshaft sensor ok,code 332,relpaced egr,vacume switch and pressure sensor,maf sensor.catalytic converter ok,replaced temp sensor,injectors working,nothing helps
Apr 15, 2010 at 8:41 PM
