1994 Ford Explorer Burned relay
1994 FORD EXPLORER
KGMONEY10
Electrical problem
1994 Ford Explorer 6 cyl Two Wheel Drive Automatic
My blower motor quit working. I keep blowing replay's under the hood and it has actually burned the plastic where it goes in the fuse box. I can put a new relay in and it will run about 15 minutes and then burn up again. What could be causing this problem?
Nov 8, 2009 at 2:22 PM
MATHIASO
  • 1,209 POSTS
https://www.2carpros.com/forum/automotive_pictures/46384_relay_burns2_1.jpg
the relay is power by the fuse # 5 in the power distribution box, remove the fuse and check for corrosion. check the rating on it . if the plastic is burn, or cause relay contact to contact each other, change the plastic. Check for high resistance in the blower motor. (sending the diagram in your email)
Nov 9, 2009 at 6:07 AM
