Auto locking hubs
1994 FORD EXPLORER
117,000 MILES • 6 CYL • 4WD • AUTOMATIC
GRIZZLYEXPLORER
I own a 1994 ford explorer. It has auto locking hubs. Can the hubs be replaced with manual locking hubs from the same type of vehicle. I'm hoping. I am wondering if I will have to manually lock them in from outside the vehicle then push the button inside on the dash?
thank you
Sep 22, 2009 at 1:10 AM
Yes they can be replaced with manual locking hubs. And yes, you will need to lock them in then push the 4x4 button.
Sep 23, 2009 at 8:17 AM
FREDSANFORD1962
I'm changing the rotor out on the front driver side. I can't get the axle out far enough to get the spacer washer back on. The passenger side went well with no problems. I've pried and pulled with no results. I only need about 2mm more. The axle has no internal threads so I can't use a slide hammer. I'm at a loss and I need the car tomorrow.
Apr 28, 2020 at 1:15 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
Look at diagram is problem plastic spacers?
DOCFIXIT
  • 18,828 POSTS
Sorry trouble with new site cannot attach diagram will try again
RWEMPIRE
93 ford explorer auto locking hubs makes clunking noise when making left or right turns
The factor auto hubs were a lot of trouble. chances are the gears in them are worn and slipping. If they need replaced, I recommend getting manual locking ones.
