1994 Ford Explorer 4 wheel drive button will not put it in
1994 FORD EXPLORER
300,000 MILES • 6 CYL • 4WD • AUTOMATIC
DUNIVIN
cant get it in to 4 wheel drive by pushing the button
Dec 28, 2008 at 10:20 PM
JGAROFALO
  • 489 POSTS
Most likely, the motor on the transfer case is the problem. There is an electric motor on the rear of the transfer case that does the actual shifting. Through a set of contacs and switces in the motor, it closes a contact that lights the 4X4 light inside the car. There is also the possibility of a bad pushbutton. This is a less freguent problem, but is also a possibility.
Dec 30, 2008 at 5:59 AM
