Im trying to drain some transmission fluid out but cant find the transmission plug to do so, do you know where its located
Oct 10, 2009 at 5:59 PM
OBXAUTOMEDIC
CERTIFIED EXPERT
There is no Transmission Drain Plug. I order to remove some of the fluid you will either have to loosen the bolts around the pan or get about 4 foot of hose that will fit down the Transmission Fill Tube and siphone it out.
