1993 Ford Explorer transmission is leaking fluid badly
1993 FORD EXPLORER
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
RWEBB3890
my transmission is leaking transmission fluid
Aug 2, 2009 at 5:35 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
The most common pace for a transmission oil leak is the pan gasket, out put shaft seal, cooler lines or front seal, you will have to get the car on a hoist and have it cleaned, you will see where the oil is leaking from with it idling in park, start here.
mark (mhpautos)
Aug 2, 2009 at 5:42 PM
