its probably staying engaged, you could cause further problems if you don't address this ,like broken flywheel teeth. your starte is getting stuck. its usually a problem with the starter not your vehicle. you'll need to change it or rebuild it
May 18, 2008 at 8:36 AM
BLACKOP555
CERTIFIED EXPERT
after it starts it grinds or it grinds when attempting to start the truck?
