1993 Ford Explorer Shifter
1993 FORD EXPLORER
75,000 MILES • 6 CYL • 4WD • MANUAL
SFOWARDBOY4
Sometimes while driving the explorer for an extended period of time, when I put the shifter into the standard neutral position, it falls limp towards the neutral spot between first and second gear. Also when I put the truck in any of its 5 speeds the shifter stays in gear, but still falls limp towards first and second (does not go past the gate for the gear though). I'm assuming the truck will need a new return system in the shifter, but I also would like to know if there are any bushings that should be replaced as well while doing this.
Sep 23, 2010 at 11:05 AM
Have you checked the linkage / bushings?
Sep 23, 2010 at 8:47 PM
