1993 Ford Explorer Need help asap
1993 FORD EXPLORER
100,000 MILES • 6 CYL • 4WD • MANUAL
PUGZ1985
  • 4 POSTS
I have a 1993 Ford Explorer XLT 5 spd with about 100,000 miles on it. I put a new clutch and cylinder in it in 07. I was driving to work today and came to a stop and when i started to go i let the clutch out and got nothing but rpms. No grab what so ever. I have full clutch pedal and pressure and it goes in and out of gear but the truck won't move even a little. This happened with no warning. It was running fine until today. Any ideas whats wrong with it??? Please help!!!
Feb 23, 2010 at 3:50 PM
Is there any noise associated with the problem?
Feb 24, 2010 at 6:37 AM
PUGZ1985
  • 4 POSTS
i heard a little click noise when i put it in first and after that nothing. everything sounds normal. just that when i let out the clutch i dont get anything.
Feb 24, 2010 at 12:29 PM
SCOTTY DEE
  • 592 POSTS
Here's a possibility.
Something has broke or come loose in the shifter linkage. You can get a look inside there without too much hassle. Remove the screws from the shift boot retainer and get a look. A flashlight and a small mirror you can put at an angle will be helpful. Let me know what you find out.
Feb 26, 2010 at 12:14 PM
PUGZ1985
  • 4 POSTS
Thankyou for responding. Are you ruling out clutch and transmission? And if it is what you said is it a complicated and expensive fix?
Feb 26, 2010 at 6:57 PM
SCOTTY DEE
  • 592 POSTS
I got your email.
Feb 26, 2010 at 7:24 PM
PUGZ1985
  • 4 POSTS
My
email address is [email protected] I dont remember if i gave it to you. thanks again!!
Feb 27, 2010 at 7:58 PM
