1993 Ford Explorer engine surging
1993 FORD EXPLORER
MCUP3
Engine Mechanical problem
1993 Ford Explorer 6 cyl Four Wheel Drive Automatic
my 93 Ford Explorer starts up but then, when it is in idle, the RPMs surge from 500 to 1500 for 1-3 min or so, and then the car dies. I just replaced the starter, and it wasn't doing this prior to the repair. Could it have some thing to do with the other soleniod mounted on the fender?
Jan 13, 2010 at 12:01 PM
Welcome to 2carpros and TY for the donation
Disconnecting the battery to replace the starter will cause the computer to lose it memory. It probably needs to undergo an idle relearning process-it has nothing to do with the solenoid
Relearning procedures:
Place automatic transmission in "P" or manual transmission in Neutral position. Ensure the emergency brake has been set and all accessories are turned off. Start engine and bring to normal operating temperature. Allow manual transmission vehicle to idle in Neutral for one minute. Allow automatic transmission to idle in Neutral for one minute and then to idle in Drive for one minute. Once initial relearn is complete, process will be completed during normal driving.
Honestly, I don't think you did anything wrong. It sounds like the throttle position sensor. Has the check engine light come on? Also, since you worked under the hood, check for vacuum leaks. Check for disconnected, dry rotted, or damaged hoses.
Let me know what you find.
Jan 14, 2010 at 8:39 PM
