1993 Ford Explorer Axle is locked
1993 FORD EXPLORER
HUNGARIAN1234
  • 6 POSTS
Drive Train Axles Bearings problem
1993 Ford Explorer Four Wheel Drive Automatic
I replaced a u joint in the front axle and now the vehicle will only move in reverse. The drivers side REAR tire only spins in reverse even with the engine off and trans in neutral. What would cause this?
Nov 30, 2008 at 11:57 AM
JAMES W.
  • 2,394 POSTS
Are your emergency brake cables stuck at the rear wheels? Please advise.
Nov 30, 2008 at 3:57 PM
HUNGARIAN1234
  • 6 POSTS
No, the parking brake is not stuck and I can turn the wheel in backward by hand but when I try to turn it forward it feels like the transmission is in park and that wheel is locked. I've taken all four wheels off the ground and tried to get it to turn while running in both 2 and 4 wheel drive. I shut off the engine and put the trans in neutral, the right 3 of the four wheels will turn either way but not the drivers side rear. I've never run across this before and don't know if it is a differential problem or what. Any other ideas?
Nov 30, 2008 at 7:47 PM
JAMES W.
  • 2,394 POSTS
Bear with me, I'm trying to visualize this in my head. Is this a positraction or limited slip rearend? If you lift both rear wheels off the ground and trans is in park. Turn the passenger side wheel forward. Does the driver's side wheel turn backwards? Then turn the passenger side wheel backwards, does the driver's side turn forward? And, with the trans in neutral, does the left rear wheel turn backwards harder than the right?
Nov 30, 2008 at 8:33 PM
HUNGARIAN1234
  • 6 POSTS
In park if I turn the pass side wheel forward the drivers side wheel turns backward. In park the pass side wheel will not turn backward. Both seem to take about the same amount of force to turn backward while in neutral.
Nov 30, 2008 at 8:58 PM
JAMES W.
  • 2,394 POSTS
Try backing the brake shoes off on the left rear wheel and then try to turn it forward. Let me know what you find.
Dec 1, 2008 at 5:26 PM
