[quote:0b8b28ed9b="lile45"]Transmission problem
1992 Ford Explorer 6 cyl Four Wheel Drive Automatic 157000 miles
Yes my 92 ford explorer has a tranny leak. Do i mix the stopleak with the tranny fluid or do i pour the stop leak in alone[/quote:0b8b28ed9b]
I recommend that you do NEITHER!! That stuff is bad for the transmission, and will probably not stop the leak. Look it over and see where the leak is coming from. Then replace the offending gasket or seal.
Sep 9, 2009 at 2:03 PM
