[quote:886ad821ec="engineman 73"]DOES TRUCK RUN ROUGH AND/OR DIE? I WOULD CHECK FUEL PRESSURE REGULATOR ON FUEL RAIL.IF REGULATOR DIAPHRAM IS BAD IT WILL LEAK FUEL INTO VACUUM LINE THAT IS ATTACHED.[/quote:886ad821ec] i replaced the fuel pressure regulator and solved the problem thank you
Dec 5, 2008 at 5:58 PM
