1991 Ford Explorer smells like gas
1991 FORD EXPLORER
ALBERT1234
1991 Ford Explorer 6 cyl All Wheel Drive Manual
it leaks gas on the passanger side.could it be the fuel filter that leaks gas.it only leaks in the morning,puddles of gas.
May 21, 2010 at 2:28 PM
There are both fuel lines and the filter. Also, it could be leaking from the top of the fuel tank or a hole in the tank. What you need to do is clean off the lines and check it after it is parked. Also, if you have a leak, it will loose fuel pressure. If that happens, it should be hard to start.
May 21, 2010 at 8:23 PM
