1991 Ford Explorer Bad Engine Performance at intial start u
1991 FORD EXPLORER
190,000 MILES • 6 CYL • 4WD • AUTOMATIC
PSHARPE15
Upon starting up and driving the engine cold, it has very little torque. It also whines very loudly when pressing the accelerator (even when the transmission is in Neutral). This remains for about 3-5 minutes of driving (until the engine warms up). Once the engine is warm, torque increases to normal and the whining goes away. Any suggestions?
Sep 11, 2009 at 2:13 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Thank you for the donation,
Do you feel that this noise is in the engine or transmission? to my way of thinking this may be a problem in the torque converter, have you check for any unresolved fault codes with in the ECU, you won't always get a fault light shoeing up. I would also get a transmission specialist to drive this from a cold start and get their opinion, but as i said i feel that it may be a torque converter issue.
mark (mhpautos)
Sep 12, 2009 at 9:59 PM
