02 sploder brake lights wont go out
2002 FORD EXPLORER
AMCC81
the brake lights wont go out until i pull the pedal back the little bit itll move back. were is the brake switch? how does it work and how do i cure this problem?
Oct 24, 2007 at 8:41 PM
You need to adjust the brake switch on the brake pedal bracket-you need to loosen switch and adjust the plunger making sure the brake arm is lightly touching the plunger.
If the arm is depressing the plunger a certain position the brake light will continously be On. You need to adjust it to the point that it will not cause the light to come on.
Oct 25, 2007 at 1:50 AM
