98 Ford Expedition, 5.4 Automatic 4x4.
The car will barely run at idle. It usually dies. Driving is ok. At a stop I have to keep it at about 1000 RPM to keep it from stalling.
The code scanner says P0171 bank A is running lean, P0174 bank B is running lean.
I have replaced:
Air Filter
Fuel Filter
Fuel Pressure Regulator Valve
Two O2 sensers on the engine side of the catolitic converter
Idle Air Bypass Valve.
Any suggestion or comments would be appreciated.
I have replaced:
Air Filter
Fuel Filter
May 18, 2006 at 10:32 PM
