I am looking to put in an oil catch can pcv valve location please?
Nov 3, 2010 at 2:47 PM
KHLOW2008
CERTIFIED EXPERT
Hi cldchln,
2005 Ford Expedition and 2007 F150 are similar.
Item # 6 is the PCV hose. The valve is plugged into the valve cover.
2005 GMC Sierra 1500.
PCV hose is item # 716, (dirty air ) and # item # 700, (fresh air).
2007 Toyota Tundra
Nov 7, 2010 at 3:36 AM
KIMMY4400
MEMBER
Where is the pcv valve location in a 2004 4.6 ford expedition
Sep 12, 2019 at 2:43 PM
(Merged)
HMAC300
CERTIFIED EXPERT
in the valve cover rh side see pic
Image (Click to enlarge)
(Merged)
KIMMY4400
MEMBER
Can you send me a pic of the pcv part that I need to purchase. Also I've looked everywhere trying find the location where I need to replace the valve doesn't look the same as the diagram in my vehicle. Is there another truck thats compared to the 2004 4.6 ford expedition has the same location
(Merged)
KIMMY4400
MEMBER
Thanks for the information
(Merged)
HMAC300
CERTIFIED EXPERT
I sesnt a diagram of where it was located. check rock auto.com for part
(Merged)
HMAC300
CERTIFIED EXPERT
see if these help you the pcv may unscrew for removal on LH side of engine (driver's side)
(Merged)
KIMMY4400
MEMBER
Thanks again. Another question I have can you also send me a diagram of where my upstream oxygen sensors are located in my 2004/ 4.6 expedition
(Merged)
HMAC300
CERTIFIED EXPERT
they are the ones between engine and converters on exaust system.see pic. please repost a new question like this as a lot of times they are not answered
(Merged)
MELISSA1001
MEMBER
1 POST
Is the valve located under the plastic cover or on the driver's side of the cover, just below? I asked the person at an automotive store but they were unsure of it's location. A picture would be helpful.
(Merged)
SATURNTECH9
CERTIFIED EXPERT
The PCV valve is located in the upper portion of the valve cover. Here is a diagram of the 4.6L or 5.4L engines below.
(Merged)
KIMMY4400
MEMBER
Thanks so much I appreciate your help. The second diagram was a lot more accurate
(Merged)
BIGLEE33
MEMBER
I would like to know exactly where my pcv tube is located and if it will be difficult to replace for the user.
(Merged)
CERTIFIED EXPERT
What size engine do you have?
(Merged)
BIGLEE33
MEMBER
I have the 4.6 Liter.
(Merged)
CERTIFIED EXPERT
Here are the pictures I found. It is on the valve cover.
Let me know if this helps. NOTE: These pictures are from Ford, so I will assume they are correct.
(Merged)
BIGLEE33
MEMBER
Thank you so much! I was just wondering about that very hose. I will let you know if it works out.
(Merged)
ELLIOTT37
MEMBER
1 POST
bought a pcv vave and cannot find it on the engine
(Merged)
CERTIFIED EXPERT
Hi:
It's located on the valve cover. Here is a picture.
(Merged)
SABRUIN
MEMBER
1 POST
I was told by the service tech at the Ford dealership we take our vehicle to that the PCV tube is collapsed. Can you tell me where it is and how to replace it? A diagram or photo would be helpful. Thanks!
(Merged)
2CARPRO JACK
CERTIFIED EXPERT
My software doesnt have a pic of it.Follow the PCV line from the valve cover to where it attachs to the intake manifold (at back of throttle body usually), this is where it is collapsed, happens to all of them
(Merged)
OCHASER
MEMBER
1 POST
I noticed the engines idle was off and rough. I could hear a vacuum leak in the engine compartment. I found a rubber vacuum hose which had been worn and deteriorated located in the rear, right rear of the engine. It is a Y shaped or T shaped hose (cant remember, sorry). It is not a PCV Valve I believe. It is difficult to get to as it is in a very tight location. I want to replace the problem however I do not know what to call it or how to identify it. I welcome your thoughts. Thank you
Sep 12, 2019 at 2:44 PM
(Merged)
CERTIFIED EXPERT
If it is a vacuum hose, just replace the part that is bad. Chances are the part is good that it is attached to.
Let me know. Also, if you could get a picture of it and upload it for me to see, it would help. Let me know what size V8 it is.
