Let me know if you need any of the diagrams ?
Exterior Mirror
Removal and Installation
NOTE:Do not remove the exterior mirror assembly when repairing an individual part. Individual components can be installed without removing the exterior mirror.
Remove the front door trim panel. For additional information, refer to INTERIOR TRIM AND ORNAMENTATION .
Position aside the weather shield.
Disconnect the exterior mirror electrical connector.
Fig. 38: Disconnecting Exterior Mirror Electrical Connector
Courtesy of FORD MOTOR CO.
Remove the exterior mirror.
Remove the nuts.
Fig. 39: Removing Exterior Mirror
To install, reverse the removal procedure.
Install top nut first.
Exterior Mirror Motor
Remove the mirror glass. For additional information, refer to EXTERIOR MIRROR GLASS .
Remove the three exterior mirror motor screws and exterior mirror motor.
Disconnect the electrical connectors.
Fig. 40: Removing Exterior Mirror Motor Screws And Exterior Mirror Motor
Exterior Mirror Glass
Position the exterior mirror glass in a downward position to obtain a gap at the edge of the mirror.
Fig. 41: Positioning Exterior Mirror Glass
WARNING:Place a shop towel between the exterior mirror glass and the hand to avoid personal injury in the instance of glass breakage.
Fig. 42: Disengaging Mirror Glass
Disengage the mirror glass.
Insert a flat-blade screwdriver between the mirror glass tabs and the mounting plate, and rotate to separate the locking tabs from the mounting plate.
Carefully pull the top edge of the glass away from the exterior mirror housing.
If equipped, disconnect the heated mirror electrical connectors and remove the glass.
Fig. 43: Disconnecting Heated Mirror Electrical Connectors And Removing Glass
Rotate the exterior mirror glass in all directions after the installation to make sure all clips are completely attached.
Exterior Mirror Cover
Release the four retaining tabs and remove the exterior mirror cover.
Release the vertical tabs first.
The two outboard vertical tabs are released by moving them in the outboard direction. The two inboard horizontal tabs are released by moving them in the downward direction.
Fig. 44: Releasing Retaining Tabs And Removing Exterior Mirror Cover
Rotate the exterior mirror glass in all directions after installation to make sure all clips are completely attached.
Dec 15, 2008 at 7:05 AM
