where can i locate the fuel filter on this 2003 under the hood or along the frame
Jun 18, 2009 at 8:17 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
Your fuel filter is located on the inside of drivers side frame rail, close to tank. Use a flat blade tool to turn the filter protective cover tabs 45 degrees, then remove the cover. Disconnect filter fittings and remove filter.
