charging system problems
2003 FORD EXPEDITION
120,000 MILES • V8 • 2WD • AUTOMATIC
CHAOS
my vehicle was recently in storage for 2 month and my battery died. i jump started it and all was fine.4 days later the vehicle shut down. check charging system! i check the alternator and replaced the battery no joy!! can anyone assist me ?
thanks!!! semper fi !
Jan 13, 2008 at 9:56 AM
LEGITIMATE007
  • 5,121 POSTS
There is a fuse #9 that needs to be checked because it it is blow the system will not charge. here ia guide and the alternator wiring diagrams so you can see how the system works and the fuse location with a guide to help check it as well.
Check out the diagrams (Below). Please let us know what happens.
Jan 13, 2008 at 10:01 AM
CHAOS
[quote:164ff84cc4="legitimate007"]what did you find when you checked the alternator?[/quote:164ff84cc4]
The alternator is good. Both test good alternator and battery
Jan 13, 2008 at 10:10 AM
LEGITIMATE007
  • 5,121 POSTS
check wiring for a bad connection this guide will help.
Jan 13, 2008 at 10:50 AM
CHAOS
I found the connector to the alternator has bad I replaced it and everything started working again. thank you
Jan 13, 2008 at 11:08 AM
LEGITIMATE007
  • 5,121 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Jan 13, 2008 at 11:16 AM
