2003 Ford Expedition battery is discharging
2003 FORD EXPEDITION
SHARI W
Electrical problem
2003 Ford Expedition V8 Four Wheel Drive Automatic
a month ago i put in a new battery because i woke up one morning a the truck was dead, assuming this was the problem.
Now it has happened again. if i charge the battery it will start but when i turn it off it will discharge again.
So i dissconnected the neg cable and charged it again and checked the volts it remained at 12.8 over nite. I connected the neg cable and the truck started. What kind of problem should I look for?
Jan 4, 2009 at 9:40 AM
You have a short circuit within the electrical system -do the battery drain test below
https://www.2carpros.com/forum/automotive_pictures/12900_parastic_draw_1_59.jpg
Jan 4, 2009 at 10:02 AM
PRIMEFLOW
i have the same problem. were you able to determine what had caused this ? was it a short or the battery ? if it was a short, what had caused the short ? thanks for your help
Jan 25, 2009 at 8:05 AM
