2002 Ford Expedition Cruise Control
2002 FORD EXPEDITION
146,000 MILES • V8 • 4WD • AUTOMATIC
YVONNE151
  • 5 POSTS
Cruise quit working. Fuses ok Any ideas where to look next
Aug 31, 2009 at 9:27 PM
BLUELIGHTNIN6
  • 16,542 POSTS
are your speedometer, odometer and brake lamps working properly?
Aug 31, 2009 at 10:57 PM
YVONNE151
  • 5 POSTS
Yes, all of those parts are working fine.
Sep 1, 2009 at 3:51 PM
BLUELIGHTNIN6
  • 16,542 POSTS
if fuses # 5 (15 - amp) , 13 (20 - amp) and 15 ( 5 - amp) are OK, check the speed control switch assembly for damage along with the servo/actuator cable. let me know how these components look so I can further troubleshoot properly.
Sep 1, 2009 at 8:51 PM
YVONNE151
  • 5 POSTS
Fuses are good, no visible damage to speed control switch, cable is free and connected. Thank you for your help. Anything else come to mind?
Sep 2, 2009 at 5:53 PM
BLUELIGHTNIN6
  • 16,542 POSTS
try this test out and let me know the results. this does not require any special diagnostic tool.
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_909.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname2_241.jpg
Sep 2, 2009 at 7:26 PM
YVONNE151
  • 5 POSTS
When running the diagnostic test, we did get a cruise light to let us know we was in the diagnostic mode but it then continued to flash"cruise" at regular intervals. We went on to the second test and when we hit the "on" button, we had a "cruise" light but had no lights for the "resume", "coast" and "set/accel" buttons. Does that indicate that switch is bad?
Sep 7, 2009 at 6:54 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Did the "cruise" light flash once, then 5 additional times when you say it continued to flash? If so, it indicates a faulty speed control servo. Be sure to follow step 2 within 5 seconds of entering the diagnostic mode.
Sep 7, 2009 at 7:34 PM
YVONNE151
  • 5 POSTS
It did flash once and then continued to flash about every 5-10 seconds apart from flash to flash. As long as we held the button in, it continued to flash. We wasn't sure if it was suppose to be 5 quick in succession flashes or spaced apart like mine was.
Sep 8, 2009 at 4:03 PM
BLUELIGHTNIN6
  • 16,542 POSTS
ok, it will probably be best to have the vehicle scanned with a diagnostic tool. this will prevent a misdiagnosis and save you a lot of time as well.
Sep 13, 2009 at 11:22 AM
