2001 Ford Expedition PCV Valve makes lots of noise
2001 FORD EXPEDITION
122,000 MILES • V8 • 4WD • AUTOMATIC
KAHLESSW
My car is shaking when I step on the gas and seems to hesitate. Problem would come and go for a while but now its constant and the check engine lite came on now. I was looking under the hood for a vac leak and could hear and feel the PCV Valve shaking. Could this be the problem???
Jul 17, 2010 at 3:24 PM
Remove the PCV and shake it. If you hear a rattle, it is good. Make sure it isn't cracked and check the vacuum hoses and replace if needed. If there is a leak, it will cause the problems.
Jul 18, 2010 at 10:11 PM
