Horn Blowing - will not stop
2001 FORD EXPEDITION
15,000 MILES • V8 • 2WD • AUTOMATIC
CAJUNMIKE
This morning, early, the horn on my 2001 Ford Expedition started blowing and would not shut off. I had to disconnect battery cable to stop it. Any idea what is wrong?
Jan 19, 2008 at 5:10 PM
CLIFF C
I have a 2001 as well and had this same problem yesterday. Under the right wheel well you can pull of the connector to the horn which I had to do. Any ideas! this is a huge pain!
Feb 25, 2008 at 3:04 PM
CLIFF C
In answer to you ?'s. I live in Orlando so it was 80 outside. I have a keypad entry and my lights only flash when double clicking the lock button on my keychain entry.....help
Feb 25, 2008 at 3:06 PM
RGRGNDN67
Noises problem
1998 Ford Expedition V8 Four Wheel Drive Automatic
sounded my horn and it stayed on...sticky..had to pry it out...
Dec 3, 2020 at 9:26 AM (Merged)
Did the button on the steering wheel stick? If so, there is a spring that may have broken or did you spill anything that could have cause it to stick or bind?
