I am having problems with the door lock. When I push the remote or when i push inside control it sound like i is slipping. it works some times.
Jul 4, 2009 at 7:46 PM
CERTIFIED EXPERT
Are all of the locks doing the same thing or only one door?
Jul 16, 2009 at 11:25 PM
GUNFIGHTERMD
MEMBER
2000 Ford Expedition V8 Four Wheel Drive,
It is only happening to the passenger side.
Mike
Jul 17, 2009 at 9:52 AM
CERTIFIED EXPERT
Mike,
If it's only one of the doors, chances are the solenoid that actuates the lock is weak and going bad. You can check to make sure it's getting 12 volts. If it is, replace it.
Jul 17, 2009 at 3:40 PM
GUNFIGHTERMD
MEMBER
Thank you so very much, for you help with this matter.
is there are diagrams on how to remove the door panel.
Thank you.
Mike
Jul 17, 2009 at 8:20 PM
CERTIFIED EXPERT
Mike,
There is no diagram. However, it's not too hard. There are a few screws and between the panel and the door there are plastic clips. You will need to remove the arm rest. If you can't find the screws, some are hidden under plastic plugs. Use a small screwdriver to remove the plugs.
