Interior problem
2000 Ford Expedition V8 Front Wheel Drive Automatic
Power window in LF door not working. Suspect motor. Need to know how to remove int door panel to get to motor, etc. Removed top front phillips screw & can remove door handle. Presume apply pressure between panel & door interior to pop loose fasteners as for Broncos. However, applied considerable pressure, but not getting results & do not want to break anything. Are special tools helpful or required or are other methods used for removing these panels?
Apr 17, 2010 at 1:03 PM
