2000 Ford Expedition AC Issues
2000 FORD EXPEDITION
130,000 MILES • 6 CYL • 4WD • AUTOMATIC
DARO07
  • 4 POSTS
My ac blow thru the defoster vent when ever its on max ac or any other selection. However when its on FLR/PNL it keeps switching between the front and defroster vents. I have already replaced the blend door actuator but I sill have the problem
Jul 8, 2010 at 12:41 PM
I think you are looking for a vacuum leak. The vent doors are actuated by engine vacuum. When there is a leak, that is what happens. Check under the dash and the hood. If you are lucky, with the engine rinning, you may hear a hissing sound.
Let me know what you find.
Jul 10, 2010 at 12:58 AM
DARO07
  • 4 POSTS
Thanks for the reply, I went under the hood and checked all the lines this weekend I head no hissing sound. However this weekend my buddy and I are going to remove the dash board and check all the lines. Since the ac isnt bowing cold in the front just cool I figure we might as well. I have ordered a blend door just in case. Anyway it will be a good experience for the both of us since he also has an expedition. I will let you know what we find if we find anything. Your input is also welcomed
Thanks
Jul 12, 2010 at 6:47 AM
Let me know. It is a big job, so pay attention to how it comes apart.
Jul 15, 2010 at 11:05 PM
DARO07
  • 4 POSTS
Ok we took the dash board out this weekend and changed the blend door. However we still have the same porblem. AC still blowing in the defroster vent. I am thinking at this point it could be a eletronic switch or the vacumn. Any suggestions?
THX
Aug 4, 2010 at 7:38 AM
Is still say you have a vacuum leak. Did you check all the vacuum hoses?
Aug 4, 2010 at 1:56 PM
After thought, did you check all the vacuum lines under the dash? If so, have you checked the actuator itself?
Aug 4, 2010 at 5:42 PM
DARO07
  • 4 POSTS
I changed the actuator, it's brand new one from the dealer. I checked the lines under the hood. I didnt check those under the dash. I guess I will have to do that this weekend. I was told that there is a vacuuum under hood close to the battery that may cause that I checked but it seemed fine. Is there a simple way to check the vacuum lines for leaks? So far I have been doing physical checks it may be that I missed something.
thanks again
Aug 5, 2010 at 6:39 AM
My guess is the problem is under the dash. As far as checking for vacuum, the switch that runs everything has a supply line from the engine. It should have vacuum when the engine is running.
Let me know what you find. I really believe that is the problem.
Aug 5, 2010 at 11:37 PM
