1999 Ford Expedition Shaking at HIghway speeds
1999 FORD EXPEDITION
109,070 MILES • V8 • 4WD • AUTOMATIC
AB28408
  • 5 POSTS
My truck is having a terrible shake at highway speeds. Once i get over 45mph, its shaking pretty bad ---- when i turn left, it shakes a little worse; however, if i increase my speed while turning, the shaking calms.
I don't have to be turning for the car to be shaking.
I did have a broken belt in one of my tires --- and i took that tire off.....but its happening again.
No idea here. Oh, if i'm creeping @ 4mph or so and turn left (like when parking) i hear a noise like something is grinding or something....it does it at certain points as the tire rotates. sound like its coming from my front left side.
Apr 18, 2008 at 8:08 AM
LEGITIMATE007
  • 5,121 POSTS
the grinding when turning is probably your power steering. but some times you can correct that with a proper allignment because the steering is off, it makes your turn radius off therefore making you turn your wheel farther than necessary. so alignment and check tie rods/adjust. that can also make your car shake when at highway speeds, so check those out and get back to me
Apr 18, 2008 at 8:12 AM
