1999 Ford Expedition missing on no 6 at low idle
1999 FORD EXPEDITION
67,000 MILES • V8 • 2WD • AUTOMATIC
SUPER MOM
  • 6 POSTS
Have put spark plugs and wires, coil, EGR valve clearned Egr valve, fuel filter air filter, Dphd sensor, air intake sensor, It still says missing on no 6
Apr 9, 2009 at 7:53 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Check the compression on that cylinder check for a vacuum leak around that cyl and check injector is ok, do this next.
mark (mhpautos)
Apr 9, 2009 at 8:36 AM
SUPER MOM
  • 6 POSTS
I did replace the injector but not thr compresson
Apr 9, 2009 at 9:10 AM
MHPAUTOS
  • 31,937 POSTS
Check the compression and check for vacuum leaks next,
Mark (mhpautos)
Apr 9, 2009 at 9:25 AM
SUPER MOM
  • 6 POSTS
The compression is ok , vaccum line ok, what else could it be? When you come to a stop and it idles it kicks back a little not all the time. we also put a MAF sensor.
Apr 13, 2009 at 6:42 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
you will need to get a read out of the actual Kva ignition readings when it misfires, this will prove the ignition system one way or the other, but if it is only 1 cyl, you may have to re check the ignition system for No 6 not just visually but with testing equipment this may now be a job for your mechanic, let me know if you need technical information, i will post what i can.
mark (mhpautos)
Apr 13, 2009 at 7:29 PM
SUPER MOM
  • 6 POSTS
I have took it to A Ford Dealer they can not find anything. So ford dealer mechanic is no good. I took it to them 5 times.
Apr 13, 2009 at 7:41 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
this may be a fault with in the ECU, i would talk to an independent work shop about trying a test unit( This is an ECU that has been confirmed that it has no defects) this will prove the ECU to be good or day, i would go here next.
Mark (mhpautos)
Apr 13, 2009 at 7:51 PM
SUPER MOM
  • 6 POSTS
What is a ECU?
Apr 13, 2009 at 8:24 PM
MHPAUTOS
  • 31,937 POSTS
Hi there, this is the main computer that controls all engine management parameters.
Mark.
Apr 13, 2009 at 9:05 PM
