1998 Ford Expedition Gauges
1998 FORD EXPEDITION
98,000 MILES • V8 • 2WD • AUTOMATIC
EARL09
None of the gauges are working. Is this likely to be a fuse, or what are some other possible causes?
Feb 3, 2009 at 10:07 AM
Hi:
Did this all happen at once? Also, you can check the fuses, but I doubt that is the problem. Look for broken body grounds under the dask, make sure the wiring to the dash hasn't come unpluged. If everything looks ok, you may want to have the body control module (BCM) tested.
Feb 3, 2009 at 7:23 PM
