When replacing engine coolant, the strongest solution you can get is when you mix 50% coolant and 50% water. You don't want to use only water or all coolant. Coolant prevents freezing and on the opposite end of the spectrum, it increases the boiling point of water to help prevent boil overs.
As far as the coolant, I always like to recommend a universal GL5 coolant. That way, in the event coolant needs added, you can use the universal again or the traditional green coolant.
If you are replacing the radiator, here is a link you may find helpful. It explains how in general it is done.
https://www.2carpros.com/articles/how-to-replace-a-car-radiator
If you look at the attachments below, they provide the directions specific to this vehicle for replacement.
I hope this helps. Let me know if you have other questions.
See pics below.
Jun 28, 2021 at 5:09 PM
