1997 Ford Expedition Engine swap
1997 FORD EXPEDITION
176,000 MILES • 6 CYL • AWD • AUTOMATIC
SERENITYSOUL
I have a 97 ford expedition, with a locked engine. I bought a 99 ford expedition engine to replace it because I was told it would easily fit in it. However, I am now starting to run into some problems lining the new engine up. What exactly needs to be swapped out to make the 99 engine fit in correctly? Do I need an engine swap kit?
Feb 25, 2010 at 6:05 PM
We always recommend using a direct fit because there always seems to be a problem when you change years. I
First, is it the same size engine?
Feb 26, 2010 at 4:52 PM
SERENITYSOUL
Yes both engines are 4.6L 8 bolt windsor. The only difference is the years. I began trying to swap the intake manifold with sensors but the bolts aren't lining up. Any suggestions?
Feb 26, 2010 at 11:02 PM
