2004 Ford Excursion Brake lights
2004 FORD EXCURSION
SADCOCK
Brakes problem
2004 Ford Excursion V8 Two Wheel Drive Automatic
My brake lights are not working. I have replaced the bulbs and I have replaced two fuses that were marked brakes. Any other suggestions? Thanks!
Oct 9, 2010 at 12:49 PM
JDL
  • 16,098 POSTS
Do the high-mount brake lites work? If the answer is no, check the brake switch, also need to check voltage to and from the brake switch. The fuse in the diagram, you need to use a voltage tester on the fuse circuit, should be hot.
https://www.2carpros.com/forum/automotive_pictures/170934_ford_brake_switch_1.jpg
Oct 9, 2010 at 1:58 PM
LISSETTEJ
I had the same problem and it ended up being the wires came loose inside of the steering column. Very easy fix... hope this helps.
Jun 19, 2017 at 9:39 AM
Great addition to this thread! Please feel free to help out whenever you are on the site :)
Jun 21, 2017 at 5:19 PM
