2004 Ford Excursion ABS system
2004 FORD EXCURSION
JPEREZ1223
Brakes problem
2004 Ford Excursion V8 Four Wheel Drive Automatic
If I disconect the cable on the ABS sensor that goes in to the brake disc would I have any problems will my truck not brake as it should. I ask cause my ABS light is on and ever since I have push on my brake pedal hard and when I disconnect it it seems to work better.
Mar 27, 2010 at 8:34 PM
The brakes will not stop working. However, you will not have ABS if needed.
May 6, 2010 at 11:16 AM
